VIA Client autostart
  • 1.  VIA Client autostart
    Posted Feb 02, 2018 08:38 AM
    Hi all
    I installed 64-bit VIA Client 3.2.1.0.101689 a few days ago on a Win 10 Pro. It keeps on autostarting.
    I've been searching for a way to disable the autostart. From Airheads forums I found suggestion to just delete it from the Win Start folder. Done that, but every time I start it, it will reinsert itself.
    In another thread someone said this can be disabled from the client settings. There's no option for that at all.
    Arubavnic.inf -file contains this part:
    [Strings]
       DeviceDescription = "Aruba Virtual Adapter"
       Provider = "Aruba Networks"
       MTU      = "MTU"
       MediaStatus = "Media Status"
       ApplicationControl = "Application Controlled"
       Always             = "Always Connected"
    Is this "Always Connected" the culprit? If yes, what should be the value to make it manually startable?
    If this isn't it, how the devil do I stop it?
    For developers:
    While autostart can be convenient, it's not always so. It's not something I need first thing when I login. Not every VPN:d network is reachable with VIA client - I need currently three others.
    So please consider making autostart a user-configurable option. I see no technical reason why it has to start with Windows. Seems to work just fine when you start it manually when Windows is already running.
  • 2.  RE: VIA Client autostart
    Posted Feb 02, 2018 08:54 AM
    I had this issue too for a while but here is what I ended up doing.
    On windows 7 boxes, I pulled up MSCONFIG, went to the STARTUP tab and then removed/disabled VIA from there. In Windows 8/10 boxes, same principle, but done from the START tab in Task Manager. As far as Macs go, well, you are on your own there ;-)
  • 3.  RE: VIA Client autostart
    Posted Feb 03, 2018 05:06 AM
    Thank you Scott! That did the trick.
    This really should be a client configuration item, not hidden in Windows settings.
  • 4.  RE: VIA Client autostart
    Posted Feb 02, 2018 10:32 AM
    wrote:
    Hi all
    [Strings]
       MTU      = "MTU"
    For developers:
    Do you mean startup automatically or make the connection automatically?  The option to make the connection automatically is dictated by the controller configuration auto-login:  http://www.arubanetworks.com/techdocs/ArubaOS_6_5_4_X_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/aaa_authentication_via_c.htm?Highlight=auto-login
