VIA constant disconnect in a cluster
  • 1.  VIA constant disconnect in a cluster
    Posted Apr 30, 2020 01:28 PM
    Hi, we have a setup (lab environment) with 2 MCs, MC1 & MC2 in a cluster, where VIA VPN is being done to one of the MCs through an AP in the cluster. Here's a description of the problem:
    1. VPN client connects successfully. I can see ipsec SA built successfully in the logs
    2. VPN client disconnects itself constantly & rebuilds constantly, every few seconds.
    Notes:
    - Controllers clustered
    - Client connected to AP2, A-AAC is MC2
    - Client's A-UAC is MC2
    - Client VPN opens successfully to MC1, but keeps getting torn down.
    During testing, we created 2 VIA connection profiles, one for MC1 and one for MC2. We noticed that when:
    - VIA VPN to MC2, Client's A-UAC is MC2, connection is stable. No disconnects.
    - VIA VPN to MC1, client's A-UAC is MC2, constant disconnects.
    So when the client's VIA VPN controller is different from its A-UAC, the disconnect issue is seen.
    In the errorlog, we see the following log repeatedly:
    datapath-userrem(ipv4/L2) failed: mac=00:00:00:00:00:00 IP=172.16.10.50, action=0x8001
    Thoughts?
  • 2.  RE: VIA constant disconnect in a cluster
    Posted May 04, 2020 04:27 PM
    Take a look at this: https://support.hpe.com/hpesc/public/docDisplay?docId=a00098430en_us
    VIA itself does not support controller/MD clustering in AOS8, as it does not have the notion of active anchor and standby anchor for the VPN session. VIA controllers are typically standalone or VRRP active/standby.
  • 3.  RE: VIA constant disconnect in a cluster
    Posted May 04, 2020 04:30 PM
    I asked someone internally for comment, and this is what they responded:
    "We have not tested this type of scenario before. But the big problem in this test is that the VIA client also functions as a wireless client which connects to a CAP.
    A typical VIA client should come from a remote site and it has no way to connect to a CAP which terminates at the same VIA controller, and its MAC address a all “0”, it wont have a UAC as campus wireless client. In a word, this test is not a valid test for our VIA solution. I will recommend testing with a client which does not connect to campus AP which terminates to the same VIA controller."
  • 4.  RE: VIA constant disconnect in a cluster
    Posted May 04, 2020 06:00 PM
    Ok good to know, thank you both!!
