Network Management
VIA does NOT detect a "Trusted" network
  • 1.  VIA does NOT detect a "Trusted" network
    Posted Jul 27, 2022 10:57 AM
    We have installed the VIA VPN, along with Windows and Android clients.
    Basically it works fine, but we have an issue with the "Trusted" network detection.
    When I'm connected on a "Trusted" it does detect it and always tries to VPN on it.
    According to the doc, the "Trust" is detected by sending HTTPS/HEAD on the "internal_ip".
    When I connect manually with HTTPS I'm getting a browser connection, with the warning saying that it NOT secured.
    Do I need a valid certificate on the "internal_ip", which is on the EDMZ zone?
    Below the doc summary:
    " the VIA client automatically detects whether the user is connected
    to a trusted or untrusted network by sending a HTTPS HEAD request to the
    internal IP of the controller <https:// <controller's internal ip>/via >. If the VIA
    client receives a HTTPS response with the expected X-VIA header, the user is
    considered to be on a trusted network. An IPsec connection is established only
    if the user is connected to an untrusted network. "
    Have you ever fall in this situation, or any idea on what action to take.
    Thanks in advance.
    Ray
