VIA Failed to Establish Secure Session
  • 1.  VIA Failed to Establish Secure Session
    Posted Mar 13, 2016 08:33 AM
    VIA client version: 2.3.2
    Controller version:6.4.3.6
    Does anyone have any idea?
    Attachment(s)
    txt
    via_lab_20160313.txt   28 KB 1 version
  • 2.  RE: VIA Failed to Establish Secure Session
    Posted Mar 13, 2016 08:43 AM
    Do you see authentication failures or passes on Clearpass in the access tracker when you try to authenticate?
  • 3.  RE: VIA Failed to Establish Secure Session
    Posted Mar 13, 2016 09:19 AM
    Dear Colin,
    I didn't see any authentication failures or passes on Clearpass in the access tracker when you try to authenticate.
    Clearpass configuration had been attached.
    Attachment(s)
    docx
    ClearPass with VIA VPN.docx   146 KB 1 version
  • 4.  RE: VIA Failed to Establish Secure Session
    Posted Mar 13, 2016 09:27 AM
    @Derek_Sun wrote:
    Dear Colin,
    Is there a firewall between your VIA client and the controller?
  • 5.  RE: VIA Failed to Establish Secure Session
    Posted Mar 13, 2016 08:53 AM
    A quick look, I noticed that your vpdn group l2tp is disabled:
    vpdn group l2tp
      disable
      client configuration dns 168.95.1.1
      no ppp authentication PAP
  • 6.  RE: VIA Failed to Establish Secure Session
    Posted Mar 13, 2016 09:23 AM
    Dear Zach,
    I was configured follow the "VIA APP Note" version 1 page 29.
    It shows "enable L2TP" uncheck.
  • 7.  RE: VIA Failed to Establish Secure Session
    Posted Mar 13, 2016 09:49 AM
    A couple of things you need to have in place for VIA to work properly (some of these you may have already in place)
    - The controller needs a public IP address allowing port UDP/4500
    - make sure that the inner IP addresses is a routable network in your infrastructure (l2tp pool)
    - and Zach pointed out you need L2TP enabled
    - In ClearPass you need to add the Inner IP Addresses as a radius client ( Network > Devices > )
    - And your service needs to allow PAP as a authentication protocol
    Sent from Outlook for iPhone
