Via gui startup and domain pre login
  • 1.  Via gui startup and domain pre login
    Posted May 15, 2020 02:50 AM
    Do anyone know if you can get the via to startup faster.
    We got block traffic until vpn is up and the via client is a long time to starte can when you enable autologin on the controllere it just creates a shourtcut in the windows start and then starts when it reaches that shoutcut.
    Should domain pre login just start the via service/client before login and the block the traffic until its on trusted or the vpn is up.
    We got eap-tls and a computer cert in the computer store, but the via dosn't connect before login.
