Is there a way to put the option flags within the MSI itself, such as using the editor ORCA? Then we can deploy this via a GPO, rather than having to script it with a batch file, etc.?
We were able to customize this by editing the MSI with ORCA and placing the "switch" variables under the Property Section.
A screenshot is attached that shows the settings used when editing the MSI in Orca. Ignore the DirectoryTable section.
Thanks for the follow up Marcus. If you end up documenting any of this, please share with the community. "Kudos" to you.
