Via sometimes credentials
  • 1.  Via sometimes credentials
    Posted Dec 07, 2012 04:11 PM
    I have VIA up and running and on IOS and Android devices it will use the default-via-role, however when i use the OSX client it will grab the role from the internal DB account.    Why the difference between connections?
    Running 6.1.2.3 of code.
    As a bonus question, i upload custom logo to the <controlerip>/via  page and it still uses aruba logo for initiail login screen.
  • 2.  RE: Via sometimes credentials
    Posted Dec 07, 2012 04:31 PM
    The MAC OSX Clients uses the Default VPN role, for now, because it uses the mac L2tp vpn client.  That will be changed eventually.
    Please see the VIA vrd here:  http://www.arubanetworks.com/wp-content/uploads/VIAAppNote_2012-06-11.pdf
  • 3.  RE: Via sometimes credentials
    Posted Dec 07, 2012 05:10 PM
    All users are coming from a internal db.  They all had the role set to guest.    However when the user would login from the ios device they would receive the role of default-via-role.  But when same user logs in using the OSX they would recieve the role specified in their internalDB user profile "guest".  Shouldn't they instead recieve the role  default-vpn-user?
  • 4.  RE: Via sometimes credentials
    Posted Dec 07, 2012 05:59 PM
    If the server group attached to the VPN authentication is pointing to the internal database, and has a rule "value-of  blah blah" that means it will take the role of the user in the internal database.
  • 5.  RE: Via sometimes credentials
    Posted Dec 07, 2012 06:29 PM
    yup that was the problem, looks like I had dropped that line.  Thanks so much.
