Hi Micheal,
thanks for reply and the chance to get better. I finaly found it by a deep look in the logs on the clients
Mar 01 17:00:43.330 p6088 t2ddc ERROR ancert_mgmt 543 Issuer Cert is not found in MS or VIA cert store for ... Certificate Authority
Mar 01 17:00:43.330 p6088 t2ddc ERROR anike_mocana_cbh 1919 CHILD_SA [v2 I] failed
Mar 01 17:00:43.330 p6088 t2ddc INFO anike_mocana_cbh 1921 , status = -7600
Mar 01 17:00:43.330 p6088 t2ddc ERROR anike_mocana_cbh 1798 IKE_SA [v2 I] (id=0xbc2719b6) failed
Mar 01 17:00:43.330 p6088 t2ddc ERROR anike_mocana_cbh 1805 sending ike event
Mar 01 17:00:43.330 p6088 t2ddc ERROR anike_mocana_cbh 1810 IKE Phase 1 SA Failed status = -7600
Mar 01 17:00:43.330 p6088 t2ddc DEBUG anikeimpl 566 is 132IKE Fragment Length is 868C:\Code\arubabuild\agent_windows\externals\third_party\mocana\src\ike2\ike2_frag.c (351): errorCode = 3
As this is hard stuff I appreciate these documentation.
Cheers
Dirk
Original Message:
Sent: Mar 06, 2022 06:41 AM
Subject: VIA status codes
Was this working before and then started recently?
The error code 7600 refers to ERR_CERT, however that in itself is not clear what exactly the problem is, but obviously is something to do with certificates.
I agree we need to do better in terms of documenting these error codes and is something that is being worked on.
Michael Clarke
Original Message:
Sent: Mar 01, 2022 05:52 AM
Cheers
Dirk
Original Message:
Sent: Mar 01, 2022 05:43 AM
Hi community and support,
I would like to refer to this post VIA status codes? | Security (arubanetworks.com) as I think an offical document from Aruba is important for users and worth for Aruba Networks. Troubleshooting is very hard and everything to get a better look is helpful. @Aruba: Please do not hesitate too long.
Actualy I try to find out what's the cause of error message: Failed to establish secure session Code:-7600
The impact is clear but not the cause.
Cheers
Dirk
