VIA test on a master/local architecture
  • 1.  VIA test on a master/local architecture
    Posted Aug 25, 2014 06:03 AM
    I would like to try a VIA deployment with a temporary licence.
    In my architecture i have a master controler and 2 local.
    I can't try it on my master controler because the temporay licence had already expired (3 times).
    So i used the provided temp. licence on a local controler.
    The VIA menu is now available on the web ui: all profiles, other etc..
    So i try to follow the config guide, but:
    Many parameters are blocked and seem to provided by the master (l2tp etc.) OK.
    The VIA parameters: there are not available on the master due to the licence and it appears blocked on the local.
    How can i edit that profiles ?
    Is there any reboot to do on the local after adding the licence ?
    Or should i need to "grant" the access to that profile on the local via the master ?
    Thanks for your help.
    Rgds
  • 2.  RE: VIA test on a master/local architecture
    Posted Aug 25, 2014 07:55 AM
    You would need a permanent license on your master controller to configure the VIA profiles that are pushed to the local.
  • 3.  RE: VIA test on a master/local architecture
    Posted Aug 25, 2014 09:37 AM
    ok thank you
  • 4.  RE: VIA test on a master/local architecture
    Posted Oct 28, 2014 12:29 AM
    Collin so you need the VIA license on the MAster controller to push  the via profiles to the local controller
    AND you would need also a VIA license on the local controller to terminate the via tunnel on the LOCAL controller???
    Cheeers
    Carlos
  • 5.  RE: VIA test on a master/local architecture
    Posted May 08, 2015 11:11 AM
    Yes. VIA licensing is done per controller.
