I am trying to use the via vpn client and authentication via certificate and IKEV1.
I would like to use the same certificate for the authentication as I have retrieved from Clearpass Onboarding and using for the WLAN. Is this possible?
The issue I am having is that the Aruba VIA client says: Invalid certifacte used for ISAKMP authentication. When i start the client it prompts me tho choose a certificate from the user store and it prompts the correct one, but after that the prompts just return and the logs says the error mention above.
I have exported my signing ca certificate bundle from Clearpass and added it to the controller and assigned it under CA Certificates for clients.
I have a IKE-policy with authentication RSA and the default dynamicmap for ipsec v1
Any thoughts, guides, ideas are welcome..its possible iam doing something wrong or have missunderstand something.
