VIA VPN, 'Keep VIA window minimized' option
  • 1.  VIA VPN, 'Keep VIA window minimized' option
    Posted Jul 06, 2020 06:20 PM
    Looks I locked all via users from the VPN, I don't know how to proceed,
    I turned on this option on the via profile 'Keep VIA window minimized', the option took effect. today I wasn't able to establish the VPN connection simply because I have a login banner to 'agree',
    right-click on via icon, the 'restore' button is grayed out,
    Can someone help on this,
  • 2.  RE: VIA VPN, 'Keep VIA window minimized' option
    Posted Jul 07, 2020 06:41 PM
    Any feedback here ?
  • 3.  RE: VIA VPN, 'Keep VIA window minimized' option
    Posted Jul 08, 2020 01:50 AM
    What version of VIA are you running? Looks like a limitation in VIA 3.0.0
    https://www.arubanetworks.com/techdocs/VIA/3x/content/rns/releasenotes.htm
  • 4.  RE: VIA VPN, 'Keep VIA window minimized' option
    Posted Jul 09, 2020 07:38 AM
    below the version that mu users downloaded from the controller
    (Master01) #show via version
    Uploaded VIA Installers
    Windows 32-bit: 3.4.1.0.1908302
    Windows 64-bit: 3.4.1.0.1908302
    what do you mean about limitation ? is it a known issue? is there a way to sort that issue out?
  • 5.  RE: VIA VPN, 'Keep VIA window minimized' option
    Posted Jul 14, 2020 09:06 AM
  • 6.  RE: VIA VPN, 'Keep VIA window minimized' option
    Posted Jul 15, 2020 02:33 AM
    One way out is to tweak the registry key. goto regedit, Computer\HKEY_CURRENT_USER\Software\Aruba Networks\VIA and tweak the registry entry under the profile used. Click "AlwaysMinimize" click modify and change the value to "0". (see attached screenshot)
    Once registry is tweaked, exit VIA and relaunch from the tray
  • 7.  RE: VIA VPN, 'Keep VIA window minimized' option
    Posted Jul 17, 2020 07:43 AM
    Hello anish,
    works correctly,
    thank you for resolution,
    I have to repeate that for other PCs,
    I think what thing that need to be added in controller setup, if login banner is configured, then the minimize option needs to be grayed out, are you agree?
