VIA VPN on iOS with OTP
  • 1.  VIA VPN on iOS with OTP
    Posted Jan 10, 2012 07:12 AM
    I'm working with a customer who uses OTP with the VIA client for Windows, works fine.
    Now they want to use the VIA client on their iOS devices, with the same authentication.
    But it doesn't work. The RADIUS server sends an challenge and then logs to the event log direct after "wrong OTP".
    I can see the same result in the Aruba security logs, like "user got challenged" and right after "reject for user".
    Do the VIA for iOS have support for this type of authentication?
  • 2.  RE: VIA VPN on iOS with OTP
    Posted Jan 10, 2012 01:49 PM
    It should be supported as a simple username/password. It would be best to get a resolution to this by contacting Aruba TAC. I believe this has been reported into TAC.
    thanks,
    Shashi
  • 3.  RE: VIA VPN on iOS with OTP
    Posted Jan 18, 2012 12:29 AM
    For VIA over iOS we dont have the OTP support
    As a workaround we can select the option to 'save user password' in the connection profile by which the user wont be asked for credentials every login
  • 4.  RE: VIA VPN on iOS with OTP
    Posted Jan 18, 2012 03:37 AM
    Thank you, let's hope we get some release notes on VIA for iOS soon, so you know what supported and not.
