VIA VPN radius flags
  • 1.  VIA VPN radius flags
    Posted Sep 14, 2022 02:58 PM
    Attempting to add a new service to Clearpass that uses Duo MFA. In the short term, goal is to target a specific VPN profile. But I'm having trouble figuring out what RADIUS rules to implement to sort VIA VPN profile authentication attempts as they come in.
    There are no Aruba:VIA radius attributes I can find, and I'm not sure what IETF attribute would apply, nor how I'd configure it so the profiles are unique controller-side.
    WiFi is easy: just target the SSID. The VPN is giving me more difficulty. Annoyingly, I can find plenty of guides for doing it with a Cisco ASA as my VPN concentrator.
  • 2.  RE: VIA VPN radius flags
    Posted Sep 15, 2022 06:13 AM
    see if this guide helps you
    https://www.flomain.de/2020/06/aruba-via-vpn-with-ikev2/
  • 3.  RE: VIA VPN radius flags
    Posted Sep 15, 2022 07:47 AM
    If there are no differentiating attributes in the RADIUS request, I think you can select authentication servers per profile, and in the authentication server set the NAS-ID, which you can use to select the service or use in your evaluation/enforcement.
