View PER (error-rate threshold) IAP
  • 1.  View PER (error-rate threshold) IAP
    Posted May 04, 2015 12:31 AM
    How do I view PER on an IAP?
    One of the ways ARM on IAP decides to change a channel is based on Error-Rate threshold, which I believe is a fancy term for Packet Error Rate (PER). I believe it is:
    > 50% PER over a 30-second period = channel change.
    What I've been doing thus far:
    # show ap debug radio-stats 0 | include "Rx Bad Fram|Rx Frames R"
    ...wait for 30 seconds. Issue same command.
    Subtract 1st "Bad Frames" from 2nd = Total Bad Frames
    Subtract 1st "Frames Recieved" from 2nd = Total Frames Recieved
    PER % = Total  “Bad Frames” / Total “Frames Received”
  • 2.  RE: View PER (error-rate threshold) IAP
    Posted May 04, 2015 07:38 AM
    MikeA,
    That parameter on the controller does not have an equivalent in IAP.
  • 3.  RE: View PER (error-rate threshold) IAP
    Posted May 04, 2015 02:51 PM
    The commands mentioned are on an IAP.
    Are you saying there is no way, other than the above commands, to view PER on IAP?
