Viewing AP Group settings from the AP
  • 1.  Viewing AP Group settings from the AP
    Posted Dec 16, 2018 01:52 PM
    Dear Experts,
    When we change any setting in AP Group, such as lms-ip/backup-lms ip, is there anyway to see it from the AP itself if console is enabled? can anyone share the command for it?
  • 2.  RE: Viewing AP Group settings from the AP
    Posted Dec 16, 2018 05:02 PM
    On the commandline of the controller you would type:
    show ap config ap-name <name of ap>
    That will tell you what configuration is applied to that access point.
  • 3.  RE: Viewing AP Group settings from the AP
    Posted Dec 17, 2018 01:21 AM
    Dear Colin,
    Thanks for the prompt response. Out of curiosity, is there anyway to check from the console of AP itself?
  • 4.  RE: Viewing AP Group settings from the AP
    Posted Dec 17, 2018 04:32 AM
    Some parameters, yes, but the the information from the console is typically for engineering (undecipherable) and scattered all over the place.  Is there a problem with viewing it on the controller?
