Viewing AP radio channel mode for Instant / Airwave
  • 1.  Viewing AP radio channel mode for Instant / Airwave
    Posted Jul 02, 2015 10:55 PM
    Hi All,
    when using a mobility controller, you can run the show ap bss table command to identify the channel width and mode (i.e. HT20 / VHT80)
    What is the equivalent command for instant? Can this be seen in Airwave?
    Scott
  • 2.  RE: Viewing AP radio channel mode for Instant / Airwave
    Posted Jul 03, 2015 01:55 AM
    HI Friend,
    You can use the same command ( show ap bss-table) to get this information, look at "PHY" column. Airwave do not have any such command.
    Please feel free for any further query on this.
  • 3.  RE: Viewing AP radio channel mode for Instant / Airwave
    Posted Jul 03, 2015 08:31 AM
    Hi scottdoorey,
    as Venu mentions, run 'show ap bss-table' on the CLI for both the controller and IAP.
    Venu, you can definitely run this command on Airwave.
    Simply Navigate to the IAP-VC that you are interested in and select the drop down "Run command for all APs" and select "AP BSSID Table".
  • 4.  RE: Viewing AP radio channel mode for Instant / Airwave
    Posted Jul 05, 2015 05:08 PM
    thanks all for the responses. Looks like i'll be raising a feature request!
