Virtual AP not split tunneling
  • 1.  Virtual AP not split tunneling
    Posted Sep 08, 2014 11:27 PM
    Not sure If I picked the correct board - sorry I'm very tired.
    So here's my issue - I have a Virtual AP profile that is using clearpass certificates/user name for access to the network. It is set for split tunneling (it hadn't been, I just changed it this evening and it seems to have kept the settings) But when I test it, the IP address it's using for the internet is the one at the office, not on the rap's location.
    I'm stumped as to why this isn't working and am looking for any thoughts on  the issue.
    thank you!
    Lirria
  • 2.  RE: Virtual AP not split tunneling
    Posted Sep 08, 2014 11:36 PM
     Can you share the output of the user role?
    show rights <NameofRole>
    Did you change the rules at all when you changed to split-tunnel?    You need to change the action for non-tunneled traffic to "route src-nat" instead of "permit"
    For example:
    ip access-list session split-tunnel-policy
      user any svc-dhcp permit (allows DHCP from controller or corporate LAN)
      user any svc-dns permit  (allows DNS to tunnel to the corporate LAN)
      user alias corp-nets any permit (allows all traffic to corp-alias through tunnel)
      user any any route src-nat  (everything else is NAT'd out the RAPs IP)
    user-role split-tunnel-role
  • 3.  RE: Virtual AP not split tunneling
    Posted Sep 08, 2014 11:50 PM
    (Aruba3400) #show rights authenticated
    Derived Role = 'authenticated'
     Up BW:No Limit   Down BW:No Limit
     L2TP Pool = default-l2tp-pool
     PPTP Pool = default-pptp-pool
     Periodic reauthentication: Disabled
     ACL Number = 78/0
     Max Sessions = 65535
     Check CP Profile for Accounting = TRUE
    access-list List
    Position  Name         Type     Location
    1         ra-guard     session
    2         allowall     session
    3         v6-allowall  session
    ra-guard
    Priority  Source  Destination  Service           Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6
    1         user    any          icmpv6 rtr-adv    deny                             Low                                                           6
    allowall
    1         any     any          any      permit                           Low                                                           4
    2         any     any          any      permit                           Low                                                           6
    v6-allowall
    1         any     any          any      permit                           Low                                                           6
    Expired Policies (due to time constraints) = 0
    No - I never had to before - but I'll check - sorry I broke the rap I was using at home and am trying to fix it. (it's been a night to say the least)
    Lirria
  • 4.  RE: Virtual AP not split tunneling
    Posted Sep 08, 2014 11:59 PM
    This is likely the problem.  You are still tunneling all traffic by using the allowall policy.  It has "permit" as the action, so all traffic will continue to tunnel, even though the VAP is in split-tunnel mode.   Any traffic you want to tunnel needs to keep the "permit" action, but any traffic you wan to split off needs the "route src-nat" action.    See the example referenced above.
  • 5.  RE: Virtual AP not split tunneling
    Posted Sep 09, 2014 12:02 AM
    For a more detailed explanation, have a look at the RAP VRD; this section explain the remote employee role:
    http://www.arubanetworks.com/vrd/RAPVRD/Chap10.html#1035957
  • 6.  RE: Virtual AP not split tunneling
    Posted Sep 09, 2014 07:09 PM
    Hmm - ok - looks like there is way more involved. We had a contractor set this up and things are definately not as I anticipated (of course finding all this out months later :( )
    So it looks like I need to setup some new user rules, new virtual AP group (this is because I use the same name for both local and RAP users - I've had to do it before sadly - just wiped it from my brain)
    So I'll do some testing/work on it this evening and see if I can get all the rules/etc in place
    thanks!
    Lirria
  • 7.  RE: Virtual AP not split tunneling
    Posted Sep 11, 2014 08:01 AM
    Hi
    It is a bit mor complicated yes.
    When activating split-tunnel, you need to make a new role for split-tunnel.
    In this role you need to specify what direction specific trafic is to take.
    As Clembo said, you are running all traffic back tyo controller via the permit rule.
    When using split-tunnel, permit tunnel traffic back to the controller and route source NAT will send traffic out locally.
    All the info is in the user guide
    Roar Fossen
  • 8.  RE: Virtual AP not split tunneling
    Posted Apr 07, 2015 08:19 PM
    Similar issue so I decided to post here.  If advised, I will create my own thread.
    I followed the steps in Post 2 originally.  I set wired port 2 on the rap to be split tunnel, and it does work properly (have home ip for web traffic).  My issue is the Virtual AP.  When I connect wirelessly to the rap, it still tunnel all traffic.
    I created "Rap-Split" Virtual AP with forward mode "split tunnel"
    I created "Rap-Split-Tunnel" AAA profile with the three roles set to Rap-Split-Tunnel
    The User Role "Rap-Split-Tunnel" has the three rules in post 2.
    Any help you can provide is appreciated. :)
  • 9.  RE: Virtual AP not split tunneling
    Posted Apr 07, 2015 09:42 PM
    When you look at the user table, what role is the user in?  Then run "show rights <RoleName>".    Also run "show user ip <IPAddress>"
  • 10.  RE: Virtual AP not split tunneling
    Posted Apr 07, 2015 10:16 PM
    I just ran the commands to compare the working wired to wireless...  and didn't see anything obvious.  Role was  RAP-Split-Tunnel on both.  For fun I flipped back over to wifi and....  it is working again tonight all of a sudden.  It worked when I originally configured, but not the past two days (including earlier before posting).  Thanks for your help!
