Network Management
Virtual Controller Assigned IP addresses not NATing
  • 1.  Virtual Controller Assigned IP addresses not NATing
    Posted Jun 13, 2018 12:36 PM
    Virtual Controller Assigned IP addresses not NATing.  The internal assigned subnet of 172.31.98.0 is not being NATd to the Virtual Controller IP as it should. This is on a Guest Defined SSID. I am running 6.5.4.7
  • 2.  RE: Virtual Controller Assigned IP addresses not NATing
    Posted Jun 13, 2018 01:43 PM
    Hi
    On which type of AP?
    Did you assign the subnet manually or are you using the magic VLAN, aka virtual controller assigned default?
