Virtual Controller Cluster Client Traffic Pattern
  • 1.  Virtual Controller Cluster Client Traffic Pattern
    Posted Dec 17, 2014 07:55 PM
    I want to know how is the traffic flow for Instant Cluster setup?
    Let say I have 3 IAP:
    IAP_1 - Virtual Controller IP = 192.168.0.10, AP IP = 192.168.0.10
    IAP_2 - Virtual Controller IP = 192.168.0.10, AP IP = 192.168.0.11
    IAP_3 - Virtual Controller IP = 192.168.0.10, AP IP = 192.168.0.12
    Client associate at IAP_2 & IAP_3 will the traffic goes back to IAP_1 first before goes to internet cloud or it will direct goes out to internet cloud ?
    Regards
    Michael
  • 2.  RE: Virtual Controller Cluster Client Traffic Pattern
    Posted Dec 17, 2014 07:56 PM
    It depends. Are you using the Instant cluster to NAT or are users being dumped directly onto a VLAN?
    Guest users being NAT'ed:  User traffic -> AP -> VC
    Traffic destined for corporate network via VPN (RAPNG):   Traffic -> AP -> VC -> IPsec tunnel
    Regular local VLAN configuration:   Traffic -> AP -> local network (switched)
    http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-understand-the-Aruba-Instant-Architecture/ta-p/182882
  • 3.  RE: Virtual Controller Cluster Client Traffic Pattern
    Posted Dec 18, 2014 07:29 PM
    My architecture is this:
    VLAN:
    Management, vlan10
    Staff, vlan 20
    Student vlan 30
    Guest vlan 40
                                                             Trunk                                        untagged 10,
        tagged 20,30,40
    Server-------------Core Switch----------------Access Switch-------------------------------Aruba IAP
    (DHCP)             (Layer 3 VLAN)                   (Layer 2 VLAN)
    So, I guess it a Regular local VLAN configuration:   Traffic -> AP -> local network (switched). Am I right?
    Regards
    Michael
  • 4.  RE: Virtual Controller Cluster Client Traffic Pattern
    Posted Jan 14, 2019 04:57 AM
    According to your scnario your data traffic  go through Virtual controller. actually APs are layer 2 deivce if they have proper IP to connect Internet gateway they can reach internet without go though controller.
    you use controller manged dhcp, so you may have to use controller to NAT client IP.
