Virtual Controller IP can not be the same as IAP address?
  • 1.  Virtual Controller IP can not be the same as IAP address?
    Posted Jul 31, 2015 04:05 PM
    I have 4 IAP205 running code 6.4.2.3-4.1.2.1_49445 with IP addresses: 192.168.0.10, 11, 12, 13, 14.
    I am planning to configure AP1 as preferred master for VC which will use IP 192.168.0.10 as well. However when I got 4 APs powered up and login to 192.168.0.10 UI, I lost AP1...as soon as I changed VC IP to something else, AP1 shows up...
    So does this mean physcial IAP 205 can not use the same IP as VC? But I do pretty much same setup with IAP215s environment with code 6.4.2.6-4.1.1.6_50009 and all are working as expected. Maybe there is a software bug in 6.4.2.3 train?
    Please advise.
  • 2.  RE: Virtual Controller IP can not be the same as IAP address?
    Posted Jul 31, 2015 04:11 PM
    Anytime I've come across a cluster where an ap had the same ip as the VC there has always been problems.
    You may have just got lucky the other time.
  • 3.  RE: Virtual Controller IP can not be the same as IAP address?
    Posted Jul 31, 2015 04:48 PM
    It cannot be the same address, no. The purpose is to have a ip address, not occupied by a specific device, that can be a proxy for the active virtual controller.
  • 4.  RE: Virtual Controller IP can not be the same as IAP address?
    Posted Jul 31, 2015 06:28 PM
    That's actually make sense however how can I explain why my IAP215 VC cluster works with same IP for IAP and VC?
  • 5.  RE: Virtual Controller IP can not be the same as IAP address?
    Posted Jul 31, 2015 11:00 PM
    Just because it works now, does not mean it will not break for a random reason later.
