Virtual Controller IP doesn't work
  • 1.  Virtual Controller IP doesn't work
    Posted Jan 23, 2020 07:22 AM
    I have 6xIAP 205 (6.5.4.10) configured together and they are working well. However when I try to get access to Virtual Controller using its IP address, it doesn't work and also, I can't ping it. I can get access using any AP IP address and I'm correctly redirected to the master. Additional information:
    1. The IP was working, it just stopped on one stage
    2. Controller IP is from the same network as AP and is set to VLAN 1
    3. I can ping controller IP from master AP but can't from any other.
    4. I haven't rebooted all AP
    5. I've restarted master what moved this function to another device but this didn't help
    Could you help me to troubleshoot this issue please?
  • 2.  RE: Virtual Controller IP doesn't work
    MVP EXPERT
    Posted Jan 23, 2020 07:47 AM
    Do you have an ARP entry for the VC on the switch? Have you configured a VLAN for the VC or left it as default? Are any other services (such as RADIUS) using the VC IP without issues?
  • 3.  RE: Virtual Controller IP doesn't work
    Posted Jan 23, 2020 11:30 AM
    Craig - thnak you for your reply.
    I've tried to get access to the switch but unfortunately can't so not able to check ARP table. VC Vlan is configured to 1 - not sure what is by default - empty or 1. Radius is main reason why I'm trying to resolve it - I don't use it at this memont but want to configure.
  • 4.  RE: Virtual Controller IP doesn't work
    MVP
    Posted Jan 28, 2020 09:18 AM
    I second the suggestion to check the ARP table for the VC IP address. If you can't remotely access the switch, can you try console access? Also be careful using VLAN 1 in a production environment - VLAN 1 is the native / default VLAN for most network gear, very easy to create network loops and have broadcast storms bring down the network. Just my $0.02.
