Virtual Controller is responding to HTTP requests on an old and unused Magic VLAN IP (192.168.10.1)
  • 1.  Virtual Controller is responding to HTTP requests on an old and unused Magic VLAN IP (192.168.10.1)
    Posted Nov 16, 2012 10:07 AM
    We are one of your distributors and I have seen this in several different networks we've setup, but here is my specific situation internally:
    Network:
     - I have wireless and wired clients sitting on a simple 192.168.201.x network
     - These clients frequently use resources from a 192.168.10.x network
    Wireless:
     - Single IAP-135, running a single SSID configured as Type: "Employee"
    Problem:
     - When a wireless client tries to reach 192.168.10.1, it would occasionally go to the IAP-135's GUI.
     - This does not affect wired clients
    My only guess is that at one point, we did have a SSID set up as Type: "Guest" and the VC's randomly selected network happened to be 192.168.10.x. Although that SSID has long been removed, it seems like the IAP / VC is still trying to claim that IP. (And even if the "Guest" SSID is still running, I don't think a randomly created network should be allowed to affect the "Employee" side anyway, right?)
    Thanks in advance!
    Josh
    Here is our current config (with personal info scrubbed)
    version 6.1.3.0-3.1.0
    virtual-controller-country US
    virtual-controller-key xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    name user-wireless
    organization user
    virtual-controller-ip 192.168.201.5
    ntp-server 192.5.41.41
    clock timezone Pacific-Time -08 00
    rf-band all
    dynamic-radius-proxy
    ams-ip 192.168.168.100
    ams-key xxxxxxxxxxxxxxxxxxxxxxx
    allow-new-aps
    allowed-ap d8:c7:c8:cb:c9:9a
    snmp-server community xxxxxxxxx
    arm
     wide-bands 5ghz
     a-channels 44,48,149,153,157,161,165,44+,149+,157+
     min-tx-power 127
     max-tx-power 127
     band-steering-mode force-5ghz
     air-time-fairness-mode preferred-access
     client-aware
     scanning
    rf dot11g-radio-profile
     spectrum-monitor
     interference-immunity 4
    rf dot11a-radio-profile
     spectrum-monitor
    ip dhcp pool
     dns-server 4.2.2.2
     domain-name domain.com
     lease-time 480
    internal-domains
     domain-name domain2.com
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    opendns domain2 61661002de7663aa7230bac58c0310a5cb54dd82678557db
    device-id 0010D78B763A8693
    mas-integration
    user guest xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx portal
    user josh xxxxxxxxxxxxxxxxxxxxxxxxxx radius
    user joe xxxxxxxxxxxxxxxxxxxxxxx radius
    user test xxxxxxxxxxxxxxxxxxxxxxx radius
    mgmt-user admin xxxxxxxxxxxxxxxxxxxxxxxxx
    wlan access-rule default_wired_port_profile
     rule any any match any any any permit
    wlan access-rule domain2
    wlan access-rule domain2.com
    wlan access-rule user
    wlan access-rule default_dev_rule
    wlan ssid-profile domain2.com
     index 1
     type employee
     essid domain2.com
     wpa-passphrase xxxxxxxxxxxxxxxxxxxxxxxxxxx
     opmode wpa2-psk-aes
     max-authentication-failures 0
     rf-band all
     captive-portal disable
     dtim-period 1
     inactivity-timeout 1000
     broadcast-filter none
     blacklist
     dmo-channel-utilization-threshold 90
    enet-vlan guest
    wlan auth-server ca-dc2008
     ip 192.168.1.9
     port 1812
     acctport 1813
     key xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    wlan captive-portal
     background-color 13421823
     banner-color 10066431
     banner-text "Welcome to the Guest Network."
     terms-of-use "Please read and accept terms and conditions and then login."
     use-policy "This network is not secure and use it at your own risk."
    wlan external-captive-portal
     server localhost
     port 80
     url "/"
     auth-text "Authenticated"
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids classification
    ids rogue-containment
    ids
     wireless-containment none
     infrastructure-detection-level high
     client-detection-level high
     infrastructure-protection-level high
     client-protection-level high
    wired-port-profile default_wired_port_profile
     switchport-mode trunk
     allowed-vlan all
     native-vlan 1
     shutdown
     access-rule-name default_wired_port_profile
     speed auto
     duplex full
     no poe
     type employee
    enet0-port-profile default_wired_port_profile
    enet1-port-profile default_wired_port_profile
    enet2-port-profile default_wired_port_profile
    uplink
     preemption
     enforce none
    l3-mobility
    #3600
  • 2.  RE: Virtual Controller is responding to HTTP requests on an old and unused Magic VLAN IP (192.168.10.1)
    Posted Nov 16, 2012 10:26 AM
    You can select what network will be distrubuted by the IAP, fo rthe guest network
    Here is the image you do it in settings, maybe you got an old firmware... you need to update it to the lastest...
  • 3.  RE: Virtual Controller is responding to HTTP requests on an old and unused Magic VLAN IP (192.168.10.1)
    Posted Nov 16, 2012 10:31 AM
    It is an internal network not guest... try using not a magic vlan with assigned by the VC... instead tag it to the IAP a vlan specially for wireless and on the switch core put in a interface vlan for that vlan... on the dhcp server well put the dhcp scope for that vlan...
    The magic vlan you use it, for guest not really for employee network
    Cheers
    Carlos
  • 4.  RE: Virtual Controller is responding to HTTP requests on an old and unused Magic VLAN IP (192.168.10.1)
    Posted Nov 16, 2012 10:32 AM
    Thanks for the reply NighShade1
    We do have the latest firmware: 6.1.3.4-3.1.0.1_35899 (2012-10-26) and I do notice that we can manually specific a Guest network range now.
    However, for us, that field is currently blank and we don't have a Guest network setup.
  • 5.  RE: Virtual Controller is responding to HTTP requests on an old and unused Magic VLAN IP (192.168.10.1)
    Posted Nov 16, 2012 10:34 AM
    It doesnt matter if you dont have a guest setup... if you put an employ network with a virtual controller assigment ip, then he will use that range you put in there...
    But like i said that magic vlan is for guest not really for employee network.
    Cheers
    Carlos
  • 6.  RE: Virtual Controller is responding to HTTP requests on an old and unused Magic VLAN IP (192.168.10.1)
    Posted Nov 16, 2012 10:40 AM
    @NightShade1: Thanks again for your replies. I think I have an extremely good understanding of the Aruba Instant, so that's why I think this is more of a bug. Especially because I have seen this in other Aruba Instant networks before.
  • 7.  RE: Virtual Controller is responding to HTTP requests on an old and unused Magic VLAN IP (192.168.10.1)
    Posted Nov 16, 2012 10:49 AM
    It does not let you put a value in there?
    or you put another network in there and does not work?
    Becuase i just tested it and worsk perfectly here...and i got the same firmware...
    Or maybe i m not understanding you what you want to do?
    As what i understand you want to change the addressing distrubuited by the VC to another....
  • 8.  RE: Virtual Controller is responding to HTTP requests on an old and unused Magic VLAN IP (192.168.10.1)
    Posted Nov 16, 2012 10:52 AM
    @NightShade1: Thank you for trying to replicate the problem :)
    My main problem is that the IAP / VC is responding on an IP (192.168.10.1) that is not even configured on the unit, which is affecting normal traffic destined for the real 192.168.10.1
  • 9.  RE: Virtual Controller is responding to HTTP requests on an old and unused Magic VLAN IP (192.168.10.1)
    Posted Nov 16, 2012 10:54 AM
    Try putting another value dont leave it in blank... maybe by default he uses that one if you dont set anything... you said it was in blank those spaces...
  • 10.  RE: Virtual Controller is responding to HTTP requests on an old and unused Magic VLAN IP (192.168.10.1)
    Posted Nov 16, 2012 11:00 AM
    If you leave it in blank you see it uses a 255.255.254.0 and it uses as default gateway by default 192.168.10.1bug2.png
  • 11.  RE: Virtual Controller is responding to HTTP requests on an old and unused Magic VLAN IP (192.168.10.1)
    Posted Nov 16, 2012 11:08 AM
    look if i put a vlan on my vc i mean im using my network interface vlan my dhcp and all... im not assigning anythign from the VC....
    and the interface of 192.168.10.1 is there... even if you not creating or using it...
    Thats your issue...
    Put a value in there whatever you not using to solve it..
  • 12.  RE: Virtual Controller is responding to HTTP requests on an old and unused Magic VLAN IP (192.168.10.1)
    Posted Dec 03, 2012 03:36 AM
    we had the same problem with a customer of us. His Radius was in the 192.168.10.0 subnet and this has always worked untill the last upgrade (last version 6.1.3.4-3.1.0.1), it stopped working, so I also think this is a bug.
    We saw that a route was added in the routing table:
    172.20.105.0 0.0.0.0 255.255.255.0 U 0 0 0 br0
    192.168.10.0 0.0.0.0 255.255.254.0 U 0 0 0 br0
    0.0.0.0 172.20.105.1 0.0.0.0 UG 0 0 0 br0
    We opened a case with Aruba and after searching a few hours they told us the same thing about the magic VLAN. After adding a network (by Aruba), indeed the 192.1168.10.0 in the routing table disappeared, but the new network was added there in the routing table with losing a whole subnet that we could use in the internal network. We then used 1.2.3.4 255.255.255.255 as a dummy network and the line disappeared completly in the routing table and everything worked as normal without losing a subnet.
    In my opinion this is a work around for a bug, because before the upgrade this was working without adding the extra network.
    Aruba told me that they don't see this as a bug with the following reason:
    "informed that it is not a work around; that the reason is that the End Customer is using the same ip scheme as that of the IAP"
