The correct number of CPU/mem/disk (system requirements) is dependent on the size of appliance that you install (MC-VA-xxxx) and is listed in the virtual controller installation guide.
Original Message:
Sent: Apr 23, 2024 09:58 AM
Subject: Virtual controller limited to 10AP's with Eval License
Hi Smith, and what was the correct configuration of CPUs?
Because I am having exactly the same problem
Original Message:
Sent: Oct 18, 2022 07:04 AM
Found the issue - the VM did not have the correct resources in terms of CPU assigned. Added the correct number of CPU's and now it reports as MC-VA-1K
Original Message:
Sent: Oct 17, 2022 01:58 PM
I have installed a virtual controller and applied and eval license. The license is MC-VA-1K. When I added the license the controller reported that device and AP count is restricted to the platform limit of 10. I have not seen this before and as far as I know the eval is fully functional for 90 days. The eval description even says this itself. Am I missing something?
