Virtual IP assignment in IAP conversion process . Help !!!
  • 1.  Virtual IP assignment in IAP conversion process . Help !!!
    Posted May 03, 2016 07:03 AM
    I will be going to deploy two controller in active/standby mode by using VRRP feature. IAP's model 215 total number of APs are 75.
    VLAN-1 subnet on both controllers are 10.10.10.0/24 and VRRP instance is created for vlan-1
    My first question - When I do convert the iap's into campus ap's, Do I need to configure the vrrp virtual IP of vlan-1 in IAP conversion process ? So in any case if the master controller would be down, all APs be shifted to standby controller by the help of virtual IP. Am I going right ?
    Second Question - Do I need to assign the VRRP virtual IP under the AP system profile in the LMS IP portion for both controllers ? ELSE do not required this step ?
  • 2.  RE: Virtual IP assignment in IAP conversion process . Help !!!
    Posted May 03, 2016 07:51 AM
    You should point your IAPs at the VRRP for conversion, yes.
    You do not need to put the VRRP in the LMS-ip, no.
