Virtual ip settings
  • 1.  Virtual ip settings
    MVP
    Posted May 07, 2013 10:04 AM
    I was under the impression that clearpass redundancy would have to be set at the authenticator level (switches/controllers)?
    I.e. I would have to add the publisher and the subscriber nodes as 2 seperate radius servers in my authenticating server group in my wlan controllers.
    Now I see however a "virtual ip settings" option in clearpass 6.1 (not sure if it was there in earlier versions).
    Is this indeed like a vrrp where I enter both publisher and its subscriber with the result that my server group only needs the virtual-ip configured?
    Any advantages of this over configuring 2 auth servers in your authenticators?
  • 2.  RE: Virtual ip settings
    Posted May 07, 2013 05:03 PM
    The virtual IP in 6.1 does indeed provide similar functionality to VRRP. You would point your devices to the single virtual IP. I think the benefits would depend on your network. If you have hundreds of switches and controllers, it's much easier to add a single RADIUS server config.
  • 3.  RE: Virtual ip settings
    Posted May 10, 2013 09:01 AM
    Can a vip be assigned to the data and management interfaces?
    I only ask as i get an error when trying to assign a vip to the data interfaces after adding a vip to the mgmt interfaces.
    cheers
  • 4.  RE: Virtual ip settings
    Posted May 22, 2013 03:12 PM
    I think your issue is that you don't have both IP addresses on the same segment
  • 5.  RE: Virtual ip settings
    Posted May 23, 2013 03:17 AM
    I know :smileyembarrassed:
    bit of a typo missed the 1 got so excited to test this new feature that I missed the typo.
  • 6.  RE: Virtual ip settings
    MVP
    Posted Jun 11, 2013 05:22 AM
    Using Virtual IP interfaces in a ClearPass Cluster:
    http://www.youtube.com/watch?v=0kk8HSoPiZQ
    High availability for a ClearPass Cluster
    http://www.youtube.com/watch?v=dHLRU_kYsUs
