last person joined: 5 hours ago
Virtual Mobility Conductor suddenly not reachable
  • 1.  Virtual Mobility Conductor suddenly not reachable
    Posted May 09, 2023 04:21 AM
    since saturday 06.05.23 is my Virtual Mobility Conductor not reachable.
    Noting was changed.
    The MC is a OS8.9.x and is runing on ESXi8.
    The MC has a IP address in the same range as the other VMs which have no issues.
    I tried to restart the MC, moved it to another Host and to another Cluster.
    That made no difference. The MC is still not reachable.
  • 2.  RE: Virtual Mobility Conductor suddenly not reachable
    MVP GURU
    Posted May 09, 2023 07:32 AM
    Do you have console access to the Mobility Conductor? What does the routing table look like. Can you ping it from another appliance on the same subnet? Have you checked to see if anyone edited the network connections in the VM settings in vmware?
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 3.  RE: Virtual Mobility Conductor suddenly not reachable
    Posted May 09, 2023 07:43 AM
    only via VM remoteconsol.
    No nothing is reachable. No one had made changes in the VMware.
    The routing table is still the same.
    The interface 0/0/0 ist up Protocol down
    We had testet a copy from an older Backup. It has the same issues.
  • 4.  RE: Virtual Mobility Conductor suddenly not reachable
    MVP GURU
    Posted May 09, 2023 07:52 AM
    If protocol is down you have a connectivity issue on the VM. You may need to get your VM team to take a look at anything that may have changed when it went down. VLANs trunked to the VM Host? vSwitches set up correctly? Etc...
    Dustin Burns
