Virtual Mobility Controller 8.3.0.1 - problems with some mobile devices
  • 1.  Virtual Mobility Controller 8.3.0.1 - problems with some mobile devices
    Posted Jul 16, 2018 06:50 PM
    Hi
    I have a strange problem, It mainly appers on mobile devices like Android smartphones and tablets.
    I have virtual controller on 8.3.0.1 version, and some 205,304 and 303 APs deployed as Campus without CPSec.
    I haven configured typical WPA2-Personal, tunneled WLAN.
    Notebooks works fine but mobile devices generally cannot get DHCP address and have concetivity problem.
    When I set Ip adress manualy is the same
    It is not rather related to radio environment, because network health seems quite high.
    I have tried some debugging, but withou effect.
    Please help
    Karol
  • 2.  RE: Virtual Mobility Controller 8.3.0.1 - problems with some mobile devices
    Posted Jul 16, 2018 07:18 PM
    Can you share the user-role you are assigning ?
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: Virtual Mobility Controller 8.3.0.1 - problems with some mobile devices
    Posted Jul 17, 2018 01:29 AM
    Hi Victor
    I use default authenticated role
    user-role authenticated
        access-list session global-sacl
        access-list session apprf-authenticated-sacl
        access-list session ra-guard
        access-list session allowall
        access-list session v6-allowall
    Generally all my config now seems very typical, although it is possible that I have forgot about something
    regards
    Karol
  • 4.  RE: Virtual Mobility Controller 8.3.0.1 - problems with some mobile devices
    Posted Jul 24, 2018 02:11 PM
    When using a static IP, the client device still does not work?
  • 5.  RE: Virtual Mobility Controller 8.3.0.1 - problems with some mobile devices
    Posted Jul 24, 2018 02:50 PM
    Hi
    Exactly, when set static IP address, it is the same, DHCP is simply the first service which the client uses, it seems that some packets arę somewhere dropped.
    There must be a difference between windows and android/Linux
    We arę after some houres od debugging with Aruba support, but at this moment without success, probably the problem will finally reach engineering team.
    Do You have any idea ?
    Karol
  • 6.  RE: Virtual Mobility Controller 8.3.0.1 - problems with some mobile devices
    Posted Jul 24, 2018 07:01 PM
    What are the particular android devices that are having problems? Since notebook computers work, I would ensure that the AP(s) are on valid channels supported by the android devices. Some older (non-802.11ac) android devices did not support DFS channels. If those are in use, that could explain the connectivity problems.
  • 7.  RE: Virtual Mobility Controller 8.3.0.1 - problems with some mobile devices
    Posted Jul 31, 2018 06:38 PM
    Hi
    Sorry for a little bit late answer, I was a week on vacations.
    I think that this is not the problem with radio and DFS channels, because in debug I can see that this devices associates correctly.
    These devices which I use are: Samsung Note 4, Lenovo Tab A, Samsung Galaxy Tab.
    Now, after some investigation it seems that when I set static IP on device it seems to work (although I had some problems before)
    So it seems that there is a problem with DHCP, but only on some devices - mainly mobile.
    There must be something wrong in VMware.
    I have configured a network with Promiscius mode, MAC change and Forged enabled and tried to change NIC teaming load balancing algorithm but without effect. (Ip hash).
    I have setup on a side one more ESX server witn Aruba VMC (on Intel NUC) and it works fine. The difference is I think that this is onlu ESX and only one NIC.
    Any idea, what can I check more ?
    Karol
