Virtual Mobility Controller as standalone ? status wanted
  • 1.  Virtual Mobility Controller as standalone ? status wanted
    Posted Mar 01, 2017 09:11 AM
    Hi there
    Some of our customers whant to order a VMC instead of a physical controller.
    I read some last year's posts that says it's not a good ID :
    https://community.arubanetworks.com/t5/Wireless-Access/Virtual-Mobility-Controller/m-p/264589
    But i can't find any clear official status about this point.
    Can someone tell me what is the supported use case for VMC ?
    What can i tell to my customers who want to use them ?
    Best regards
    Pierre
  • 2.  RE: Virtual Mobility Controller as standalone ? status wanted
    Posted Mar 01, 2017 08:40 PM
    vMCsupports a maximum of 1000 APs. If you have a network comprising less than that, you might go for virtualized environment.
    For larger networks (greater than 1000 APs I mean), you have to go for the Physical boxes.
    Below datasheet for vMC might help you:
    http://www.arubanetworks.com/assets/ds/DS_VMC.pdf
  • 3.  RE: Virtual Mobility Controller as standalone ? status wanted
    Posted Mar 02, 2017 01:15 AM
    Thank you Jibran
    Most of our coustomer's network are fare bellow 1000 Aps.
    To be certain : con you confirm they can use VMC as a standalone controller, with no need for any backup / master anywhere ?
    Regards
    Pierre
