Virtual Mobility Controller - Control Plane Security
  • 1.  Virtual Mobility Controller - Control Plane Security
    Posted Apr 24, 2017 03:14 AM
    Is it true that the VMC doesn't support CPSec at all or just cert authentication for the lack of TPM?
    Just installed a VMC with ArubaOS 8.1 and the CPSec tab is there and enabled.
  • 2.  RE: Virtual Mobility Controller - Control Plane Security
    Posted Mar 26, 2018 03:19 AM
    To be honest i had some issues getting CPEC correctly working. Eventually it seemed that after a (vMC) controller reboot a routing issue went away. Afterwards CPSEC works very good on the Aruba vMC.
    So to answer, CPSEC does work correctly on a virtual mobility controller (vMC).
