Virtual Mobility controller License stacking for scalability
  • 1.  Virtual Mobility controller License stacking for scalability
    Posted Jul 24, 2019 06:21 AM
    Hi Team,
    Just to check, for the VMC licenses, lets say I only have 20 x APs. Can I add 2 x MC-VA-10s instead of going for the MC-VA-50?
    I only saw that this is possible for MC-VA-1K, but not sure about the MC-VA-10 license tier.
    Please advise thanks.
    Ricardo
  • 2.  RE: Virtual Mobility controller License stacking for scalability
    Posted Jul 24, 2019 09:54 AM
    As far as I know you should be able to stack (2) MC-VA-10 licenses on a single VMC-50 platform.
  • 3.  RE: Virtual Mobility controller License stacking for scalability
    Posted Jul 24, 2019 09:54 PM
    Hi Jerrod,
    Thanks.
    So basically what you are saying, as long as I meet the 50 VM requirements then install 2 x MC-VA-10 licenses should be able to stack?
    Any links that you can share regarding this?
    I'm thinking the same thing but I cannot find any docs regarding this.
    Thank you.
  • 4.  RE: Virtual Mobility controller License stacking for scalability
    Posted Jul 24, 2019 10:37 PM
    There's no explicit write up on that specific question. There's two elements in licensing for VMM/VMC:
    1. The provisioned virtual appliance resources (CPU/RAM/Disk). What is provisioned or configured dictates the virtual platform sizing outlined in the Virtual APpliance Installation Guides. More CPU/RAM/Disk raises the capacity of the appliance (just like buying a large controller)
    2. What the platform is licenses for.
    So in your case, with 20 APs, you provision an MC-VA-50 (because 20 won't fit on an MC-VA-10 and we don't provision an MC-VA-20), and then you install 2xMC-VA-10 licenses. This is like buying a 7010 controller that can support 32 APs, but only licensing it for 20 APs (because a 7005/7008 won't fit 20 APs). Exact same thing.
  • 5.  RE: Virtual Mobility controller License stacking for scalability
    Posted Jul 24, 2019 10:57 PM
    Hi Jerrod,
    Thanks and understood.
    So to summarize:
    1. Buy 2 MC-VM-10 licenses for the 20 APs
    2. Spin up VM but the resources should be allocated based on the MC-VM-50 specs.
    3. After the MC-VM goes up, install the 2 licenses into the VM.
    4. Job Complete.
    Thanks.
  • 6.  RE: Virtual Mobility controller License stacking for scalability
    Posted Jul 25, 2019 07:38 AM
    You should be good to go!
