Virtual Mobility Controllers
This thread has been viewed 40 times
  • 1.  Virtual Mobility Controllers
    Posted May 31, 2019 03:49 PM
    We purchased the Aruba MC-VA access licenses for Aruba Virtual Mobility Controllers (VMC).  However, I cannot locate the OVA file(s) to download. I have a service ticket open but does anyone know where these are downloaded from?
  • 2.  RE: Virtual Mobility Controllers
    Posted May 31, 2019 05:10 PM
    I see the file at support.arubanetworks.com
    After logging in, I clicked on Download Software (3 tab along the top), then along the left ArubaOS, Standard Release, Current Release, Release 8.3 (I just picked one), Release 8.3.0.7, and then it is on the list ArubaOS_VMC_8.3.0.7_70587.ova
    I hope this helps,
  • 3.  RE: Virtual Mobility Controllers
    Posted May 31, 2019 10:38 PM
    First login into http://support.arubanetworks.com/
    And click on download software and select ARUBA OS and select 8.4.x or 8.3.x standard release as per Westcott.
    find the screenshots below
  • 4.  RE: Virtual Mobility Controllers
    Posted Jun 03, 2019 12:47 PM
    Thanks to all for prompt responses. Aruba support quickly responded to my service ticket created on HPE and enabled my access to the Downloads area. I was getting Access Denied before.
    Thanks again!
