Virtual Mobility Master - Users
  • 1.  Virtual Mobility Master - Users
    Posted Apr 22, 2020 09:51 AM
    Hello all,
    The  datasheet says that the MM-VA-500 supports 500 managed devices and 5,000 clients. What happens if we go over 5,000 clients would we need to go to the MM-VA-1K even if we have 440 AP's and 2 Mobility Controllers?
  • 2.  RE: Virtual Mobility Master - Users
    Posted Apr 23, 2020 04:00 AM
    If you go slightly over, I would not expect any issues. If you exceed the user count significantly, expect unexpected behavior as you are running outside the specifications, sizing, and what is being tested.
    The easy fix here would be to size your MM to the MM-VA-1K specifications of RAM/CPU/disk, after which it will change to a 1K 'performance' with the 500 devices licenses. You can't exceed the AP/controller count, you can go to the MM-1K platform-limit for clients.
  • 3.  RE: Virtual Mobility Master - Users
    Posted Apr 23, 2020 05:04 AM
    Hello Herman, thanks for the confirmation.
    Jason
