I am using visualRF to plan/tweak currently deployed wireless network. We have a two floor building and at the moment I am just planning for top level just to get an idea. Our APs are wall mounted and we won't be able to mount on ceiling due to building modification permission issues.
So my question is that I know when visualrf generates heat map it considers 99 percentile deployment scenario that is ceiling mounted APs and it shows me that I only need 6 APs considering 200 users and 20/radio. But for every AP which it has identified it shows same channel requirement that is for 2.4 it says channel 1 and for 5ghz it says channel 52 for each AP. Is this correct? Should I be not using three non-overlapping channels 1, 6 , and 11 in 2.4ghz band?
Also how I can relate the heat map to my deployment scenario that is wall mounted APs rather than on ceiling?
Thanks.
Farzan
