Visio Stencil for a RAP-155P and S1500 12 Port Switch
  • 1.  Visio Stencil for a RAP-155P and S1500 12 Port Switch
    Posted Feb 07, 2014 04:27 PM
    I recently purchased several of the RAP-155Ps and Mobility Switch S1500 12 Port.
    I'm trying to locate a Visio stencil for both items.
    I was able to locate an stencil for the 24port S1500 Switch.
    I cannot locate one for the 12 port switch.
    I downloaded the stencils from Aruba website.
    It doesn't appear either the RAP-155P nor the 12 Port S1500 switch was in the zip file.
    Where can I go to obtain the stencil for the RAP-155P and 12 port S1500 Mobility Switch
  • 2.  RE: Visio Stencil for a RAP-155P and S1500 12 Port Switch
    Posted Feb 07, 2014 05:04 PM
    I've attached a 1500-12P stencil.  I could not locate a 155P stencil, but did find a VRD image and attached that.  Hopefully it helps with what you need for now.
    Attachment(s)
    zip
    s1500_12p.zip   48 KB 1 version
    zip
    155-prodimage.zip   21 KB 1 version
  • 3.  RE: Visio Stencil for a RAP-155P and S1500 12 Port Switch
    Posted Feb 10, 2014 11:25 AM
    That's great! Thanks for the help!
    Anthony
