Visual RF heat map issue
  • 1.  Visual RF heat map issue
    Posted Jun 30, 2018 09:42 AM
    Hi Experts,
    I need somebody advice.
    The heat map which I generating having issue and not generating properly
    Also its showing very less blush color
    Why is it so ???
    Please help me on this
    #ALE
  • 2.  RE: Visual RF heat map issue
    Posted Jun 30, 2018 09:48 AM
  • 3.  RE: Visual RF heat map issue
    Posted Jul 01, 2018 07:19 AM
    How many access points do you have on that floor?
  • 4.  RE: Visual RF heat map issue
    Posted Jul 01, 2018 07:33 AM
    Hi Joseph,
    Thanks for your support,
    I was just doing site survey for location of Access points when i placing the AP im getting the signal range like that im not sure why ?
    Any help will be appreciated Please
  • 5.  RE: Visual RF heat map issue
    Posted Jul 01, 2018 07:51 AM
    The VisualRF page is drawn more accurately when more access points are present.  Anything under 3 or 4 access points that can hear each other would only be only providing a guess and is not really expected to be accurate.  The heat map is typically drawn based on how well access points hear each other vs. how well they should be hearing each other at a specific distance.
  • 6.  RE: Visual RF heat map issue
    Posted Jul 01, 2018 09:48 AM
    Please find my heat map what i generated is correct or wrong ?
    Also in earlier picture why the signal not showing like this ?
    what could be the issue
    Kindly suggest me
  • 7.  RE: Visual RF heat map issue
    Posted Jul 02, 2018 05:45 AM
    Hi
    When we upload floor image to visualRF, it will divided in to more than 2000 grid cell in backend and all cell have same (x,y) measurment value.
    VisualRF colors number of grid cell based on transmit power value and singal strenght, if grid cell size is large and -55dbm singal strengh does not reach the corners of the single grid it wont show any color. I checked the heatmap screen shots which you have shared, it looks first floor map grid size is large because of that you are not seeing proper heatmaps.
    Note: Make sure while uploading image try provided accurate height/wedith mesausrment values.If image is already uploaded you can set measurments value using resize option.
