Visual Rf plan.
  • 1.  Visual Rf plan.
    Posted Apr 11, 2013 05:17 AM
    Hi guys! :smileyhappy:
    i have a simple question, i have doing a simulation with viasual RF plan, when i want see the heat map, for the coverage of the ap, i see three colors, red green and light blue.
    now, the areas that have the light blue color, are areas good ?
    what is the speed in these areas?
    are these areas acceptable?
    notes.
    i use rf Plan version 7.4.0
    and the access points are the 105 AP.
    i use both radio frequencies 2.4 and 5 ghz.
    thanks.
    Bye andrea.
  • 2.  RE: Visual Rf plan.
    Posted Apr 11, 2013 08:40 AM
    The red orange and green indicate signal strength of -45, -55 and -65 and should give you connectivity. The blue is -75 and won't give you very good signal as indicated by the signal strength mentioned above.
