There is a trick I found for having continuous walls:
If you draw a planning region, in the bottom right is a checkbox for "Save Region as walls". The region can be built with the click-click-click I think you're looking for. After you've finished the area, right click and delete the region, which leaves the walls behind.
I hope this helps!
- jhenley
