Visual RF plan import
  • 1.  Visual RF plan import
    Posted Jul 27, 2015 07:36 AM
    Hi, have installed visualrf plan on a server and am attempting to migrate plans off old S1 controller. Have sucessfully imported the campus/buildings but no maps, any help appreciated.
  • 2.  RE: Visual RF plan import
    Posted Jul 27, 2015 07:39 AM
    What version of ArubaOS?
    What version of Airwave?
    Can you export the plans to a laptop version of VisualRF?
  • 3.  RE: Visual RF plan import
    Posted Jul 27, 2015 07:47 AM
    Colin, old controller was 6.x.x cant recall exact version, visualrf plan is
    VisualRF Plan
    Version: 7.7.rc1 (build: 454)
    Build Date: 2015-01-15 10:48 PST
    Java Runtime Version: 1.6.0_22
    not tried on laptop, is it worth a try ??
  • 4.  RE: Visual RF plan import
    Posted Jul 27, 2015 08:02 AM
    Stunshot, since you do not know the version of the export, you should try it on the laptop, yes.  I am not sure there is an alternative.
  • 5.  RE: Visual RF plan import
    Posted Jul 27, 2015 08:20 AM
    Worth trying with a different RFplan version do you think ?
  • 6.  RE: Visual RF plan import
    Posted Jul 27, 2015 08:57 AM
    I did not see that you already tried it on a laptop. You should probably open a case with TAC just on case the export is corrupted.
