Visual RF Plan wont import .dwg
  • 1.  Visual RF Plan wont import .dwg
    Posted Oct 30, 2012 08:35 PM
    Hello all,
    im using the following version of VisualRF plan on win7x64
    VisualRF Plan
    Version
    :Build Date:2012-03-29 07:36 PDT
    Java Runtime Version: 1.6.0_22
     VisualRF Engine Version 7.4.0 (build: 315)
    :VisualRF Engine Build: 7.4.0
    VisualRF Engine Database: 63559
    VisualRF Data Path: D:\IOC site plans
    VisualRF Plan Static:63557
    Now ive created campuses, and buildings, but when i try import a floor plan using cad drawings (.dwg) the software just shows a black screen where the drawing should be, and wont let me manually enter dimensions. If i click the b&w option, the "loading image" icon appears, the software then locks up and i have to use task manager to close it.
    I have no issues with other filetypes, but my issue is i have hundreds of floorplans i need to create and all are cad. i dont have software to convert them (tried shareware and trial versions have limits)
    so is there a solution to convert them for free (preferably batched) or is there an issue with my version of VRF ?
    My apologies that my first post is a question. Just found this website and im running out of hair.. ;)
    Regard's
    paul
    ps: ive attached a .dwg of the type im trying to work with
  • 2.  RE: Visual RF Plan wont import .dwg
    Posted Oct 30, 2012 11:16 PM
    It looks like you have an older copy of VisualRF Plan:
    VisualRF Plan
    Version: 7.5.0 (build: 344)
    Build Date: 2012-08-13 02:56 PDT
    VisualRF Engine Version: 7.5.0
    VisualRF Engine Build: 65853
    VisualRF Engine Database: 54429
    VisualRF Data Path: C:\Program Files\VisualRF Plan\data
    VisualRF Plan Static: Unknown
    All Rights Reserved. Copyright (c) 2002-2012, Aruba Networks, Inc.
    Also, I didn't see an image attached to the post for me to try (it might have been stripped from the post).  Perhaps you can open a support case (support@arubanetworks.com), and they can escalate to me if needed.  Support will be able to confirm is there's an issue parsing the layers from the dwg file.
  • 3.  RE: Visual RF Plan wont import .dwg
    Posted Oct 30, 2012 11:46 PM
    Hi Rob,
    Im meeting Janet Stubbs and Raphael Zaks again tomorrow in Canberra to give me the latest copy of the software. Perhaps i can give them a disk with some example .dwg's and ask them to forward directly to you to check??  Hope to get on top of this asap..
    regard's
    paul
  • 4.  RE: Visual RF Plan wont import .dwg
    Posted Oct 31, 2012 12:01 AM
    That works.  Another option is to open a support case, support can provide you credentials to an FTP site where you can upload several plans.  That might be quicker and more direct.
  • 5.  RE: Visual RF Plan wont import .dwg
    Posted Oct 31, 2012 12:04 AM
    Thanks again Rob. Will do so tomorrow if i have no luck with the new version..
  • 6.  RE: Visual RF Plan wont import .dwg
    Posted Nov 06, 2012 03:38 PM
    Hi Rob, Latest version fixed the problem. Thanks so much..
  • 7.  RE: Visual RF Plan wont import .dwg
    Posted Nov 06, 2012 03:55 PM
    Great, thanks for the update.
