Visual RF Tool Plan - Image is not loading when uploading floor plans
  • 1.  Visual RF Tool Plan - Image is not loading when uploading floor plans
    Posted Mar 26, 2014 04:20 AM
    Currently, I have installed Visual RF Tool which I am experiencing the image is not downloading (when I try to upload the floor plans).
    I have enclosed the screen-shots for your perusal.
    Please kindly advise.
    I am running on WIndows 7.
  • 2.  RE: Visual RF Tool Plan - Image is not loading when uploading floor plans
    Posted Mar 26, 2014 02:56 PM
    This is best handled in a support case.  I suspect that there was a crash in the VisualRF log that can shed some additional details.
  • 3.  RE: Visual RF Tool Plan - Image is not loading when uploading floor plans
    Posted Mar 26, 2014 10:07 PM
    I have raised a support case. Refer to Case ID: 1522046
  • 4.  RE: Visual RF Tool Plan - Image is not loading when uploading floor plans
    Posted Mar 28, 2014 07:08 PM
    Was the current VRF Plan version the first ever installed?  If so, it may be a good idea to try this:
    1) uninstall
    2) install the older version I uploaded to the support site
    3) upgrade to the newer version
    4) then try upload again
    DE17459 was recently filed for a different issue involving import/export issues had this as a suggested workaround.  I'd be curious to see if it's true but can't reproduce since my laptop has gone through several versions of VRF Plan.
  • 5.  RE: Visual RF Tool Plan - Image is not loading when uploading floor plans
    Posted Mar 31, 2014 04:42 AM
    Hi Rob,
    The problem still persist.
  • 6.  RE: Visual RF Tool Plan - Image is not loading when uploading floor plans
    Posted Mar 31, 2014 05:35 AM
    See attachment, the image is not display when I upload the floor plan.
