Thank you. The ACad is 2013 - I will have to look at the specific version - it is not on my current PC. The files are .dwg and the walls and everything are there post and after I import - they are there in the diagram but just as a picture it seems. There is no reference data with the files I am importing.
I am going to open a case now and attach files. I appreciate the advice.
Tony
