VisualRF Beamwidth and Orientation blank
  • 1.  VisualRF Beamwidth and Orientation blank
    Posted Feb 27, 2014 12:57 PM
    In VisualRF and VisualRF Plan, the Beamwidth and Orientation fields are blank and not available for modification.
    It happens in both IE and Chrome and with an up to date versions of Java and Flash
  • 2.  RE: VisualRF Beamwidth and Orientation blank
    Posted Feb 28, 2014 05:19 AM
    What version of Airwave and what AP?
    I've had issues with that in the past with AP134 (can't remember the Airwave version at the time).  It was fixed in a later version, but TAC assisted me with a workaround/fix so I could do it without having to upgrade.
  • 3.  RE: VisualRF Beamwidth and Orientation blank
    Posted Feb 28, 2014 08:00 AM
    WorlisMan,
    What access point is that?
  • 4.  RE: VisualRF Beamwidth and Orientation blank
    Posted Mar 05, 2014 08:47 AM
    Yes, it's AP-134s
  • 5.  RE: VisualRF Beamwidth and Orientation blank
    Posted Mar 05, 2014 01:59 PM
    what version of Airwave is this?
  • 6.  RE: VisualRF Beamwidth and Orientation blank
    Posted Mar 06, 2014 07:32 AM
    7.6.6 but it also does the same thing in "VisualRF Plan"
  • 7.  RE: VisualRF Beamwidth and Orientation blank
    Posted Mar 06, 2014 08:56 AM
    going on my notes from when I raised a TAC case, the issue is fixed in 7.7.4.
  • 8.  RE: VisualRF Beamwidth and Orientation blank
    Posted Mar 10, 2014 08:36 AM
    Thanks. Is there a update to VisualRF Planner too? It would be very helpful if there was, I'm in the middle of a huge deployment and I can't afford the time to upgrade Airwave to the latest just in case there are issues.
    EDIT: I just went back to Support's Software download page and got a message that the VisualRF Plan is no longer supported and had a link to a new version. Here's the new link....
    http://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/EntryId/4830/Default.aspx
