Network Management
VisualRF BoM export not working
  • 1.  VisualRF BoM export not working
    Posted Mar 22, 2016 06:17 PM
    I'm having a problem with VRF not exporting the BoM, backup zip works fine. It all used to work, recently upgraded my entire platform from Win 7 and Office 2010 to now Win10 Office 2013 VRF version 7.7
    I'm assuming its a application issue with Java or MS Office, not allowing VRF to open the Word.
    I searched and did not turn up any results, does anyone have any advice? I cannot go back to the old setup.
    Thanks! Marc
  • 2.  RE: VisualRF BoM export not working
    Posted Mar 23, 2016 02:05 PM
    So this is for VisualRF Plan (standalone tool)?  If so, can you please post the full versioning from the 'about' section that shows version, build date, build, and VRF data path?
    For instance, mine shows as:
    Version: 7.7.rc1 (build: 454)
    Build Date: 2015-01-15 10:48 PST
    Java Runtime Version: 1.6.0_22
    VisualRF Engine Version: 7.7.0
    VisualRF Engine Build: 87613
    VisualRF Engine Database: 80766
    VisualRF Data Path: C:\Users\rgin\visualrfplan
    VisualRF Plan Static: 87613
    If this is not VisualRF Plan, but the VisualRF within an AirWave setup, please provide the full versioning form the command line output of: # root; svn info
    [root@airwave mercury]# root; svn info
    Path: .
    Working Copy Root Path: /root/svn/mercury
    URL: http://svn.corp.airwave.com/usr/local/svnroot/mercury/tags/RELEASE_8_0_11_1
    Repository Root: http://svn.corp.airwave.com/usr/local/svnroot/mercury
    Repository UUID: 99f6a4a8-5413-0410-a0fb-e6b940866760
    Revision: 98020
    Node Kind: directory
    Schedule: normal
    Last Changed Author: sameer
    Last Changed Rev: 98018
    Last Changed Date: 2016-02-18 21:00:50 -0800 (Thu, 18 Feb 2016)
  • 3.  RE: VisualRF BoM export not working
    Posted Mar 23, 2016 05:25 PM
    OK here is what I've got, Yes VRF standalone tool.
    VisualRF Plan Version: Build Date: Java Runtime Version:   VisualRF Engine Version: VisualRF Engine Build: VisualRF Engine Database: VisualRF Data Path: VisualRF Plan Static:
    7.7.rc1 (build: 473)
    2015-10-27 15:10 PDT
    1.6.0_22
    7.7.0
    95071
    95071
    C:\Users\Marc\Documents\Aruba RFPlanner
    95071
    Java Version 8 update 73 build 1.8.0_72-b02
  • 4.  RE: VisualRF BoM export not working
    Posted Mar 24, 2016 01:51 PM
    I have tried in my test environment with same build on windows 7 system and looks like its not working. Its not a known issue. Please open a TAC case.
