**EDIT**EDIT**EDIT**
If the AP you select to 'Edit Deploy Info' is a deployed AP, then you will only see Notes.
If the AP you select is a planned AP, then you should see the full options.
If you're not seeing the other options, you may have been affected by DE15195 (an issue with planned APs) - for which there's a patch.
To patch:
Step 1: Save the attached QuickView.swf file (the attachments didn't like swf, so I added it as a zip -> extract the swf file before uploading into AMP)
Step 2: Move the old file:
# mv /var/www/html/swf/QuickView.swf /var/www/html/swf/QuickView.swf.old
Step 3: Upload QuickView.swf into /var/www/html/swf/
Do not run 'make' as that will undo the change and revert back to the original swf. The fix will also be included when a 7.6.6 is built.
Note : Recently uploaded media files are still processing:
- 334C9185-7264-4594-874D-34EC3ED54BB1-1-QuickView.zip
