Network Management
VisualRF doesn't work properly with heatmaps
  • 1.  VisualRF doesn't work properly with heatmaps
    Posted Jul 25, 2017 03:30 PM
    Hello everyone,
    I have a problem with VisualRF and its heatmaps. I have uploaded a map, measured, drawn the walls and placed 4 APs. The problem is the signal strength shown in the heatmap doesn't attenuate behind concrete walls or drywalls, the signal strength is the same in the whole map. Furthermore, if I change the APs transmit power or disable one radio under AP > Properties, the heatmap is still the same.
    Below is the heatmap:
    Am I missing anything? Is there any further option I have to enable?Please help.
    Julián
  • 2.  RE: VisualRF doesn't work properly with heatmaps
    Posted Jul 25, 2017 04:17 PM
    Hi guys,
    By the way, for this I am using VisualRF demo version 8.
    Julián
  • 3.  RE: VisualRF doesn't work properly with heatmaps
    Posted Jul 26, 2017 05:21 AM
    Hi Julian,
    It looks grid size of the floor plan is large thats the reason we are not seeing -45/-55/-65dbm singal cutoff areas. Try resize the floor plan using measure option in VisualRF.
    Pavan
