VisualRF in 8.0.0 missing map lock is there a way to get it back or how easy is a downgrade
  • 1.  VisualRF in 8.0.0 missing map lock is there a way to get it back or how easy is a downgrade
    Posted Jun 11, 2014 12:01 PM
    VisualRF in 8.0.0 missing map lock is there a way to get it back or how easy is a downgrade?  I have moved 3 access points just trying to scroll around on the page and need to do a site visit to find them and put them back in place.
  • 2.  RE: VisualRF in 8.0.0 missing map lock is there a way to get it back or how easy is a downgrade
    Posted Jun 22, 2014 08:34 AM
    good question, anyone got some info on this?
  • 3.  RE: VisualRF in 8.0.0 missing map lock is there a way to get it back or how easy is a downgrade
    Posted Jun 22, 2014 09:18 AM
    The lock does not exist in the HTML5-based version of VisualRF.  You can change back to the Flash version by going to VisualRF> Setup.  Change "Enable HTML5-based UI:" to No to switch to flash...
  • 4.  RE: VisualRF in 8.0.0 missing map lock is there a way to get it back or how easy is a downgrade
    Posted Jul 10, 2014 11:47 AM
    This feature will be available in 8.0.2, we are working on adding it to the html5 version. It will always default to lock (irrespective of what the state was before) btw since we don't have the "undo" functionality.
    Sujatha
