VisualRF - manually drawing walls - it can't be this hard
  • 1.  VisualRF - manually drawing walls - it can't be this hard
    Posted Jul 22, 2015 10:26 AM
    (sorry if I'm posting in the wrong location, not clear from choices where to go with this)
    So, VisualRF -- have to draw and edit walls
    I'm not used to having so little control with a linedrawing app (I'm used to Freehand/Illustrator/Bluebeam)...
    I seem to have times where I can not select existing walls--at certain points, the only thing the app wants to do is create new ones--which is maddening.
    • Any way to constrain (make line 100% vertical or horizontal) while drawing a line?
    • Is there any trick to getting into "selection" mode, as opposed to "draw new wall" mode?
    • There has to be an option to get VRF to turn off the warning prompt ("Delete Selected Items?") that pops up EVERY TIME I WANT TO DELETE A SINGLE POINT/NODE.
    • Shortcut keys? Are there any?
  • 2.  RE: VisualRF - manually drawing walls - it can't be this hard
    Posted Aug 03, 2015 06:09 PM
    This makes a compelling feature request.  Please add to the ideas portal in the support site.  Currently there's only the manual path for drawing walls, but I will bring up your suggestions with Product Management.
  • 3.  RE: VisualRF - manually drawing walls - it can't be this hard
    Posted Aug 04, 2015 09:08 PM
    Can we also find out when we can import AutoCAD files and have the walls on certain layers automatically added? This was one of the only features from Juniper/Trapeze Ringmaster that I really don't want to live without. At one point it was slated for *soonish* but havent heard about it since.
    We've spent months updating all of our campus maps... I'm not eager to redraw all the walls ;)
