VisualRF not listing Unknown Campus
  • 1.  VisualRF not listing Unknown Campus
    Posted Dec 09, 2013 03:26 PM
    We are using Airwave 7.7.5 and we have a number of locations which are showing up as Unknown instead of in our only Campus listed.  How can we move the AP's out of a campus, so we can put them into the correct buildings within a different campus?
  • 2.  RE: VisualRF not listing Unknown Campus
    Posted Dec 09, 2013 03:36 PM
    You will have to delete those and then re-add them into the correct floor/building
  • 3.  RE: VisualRF not listing Unknown Campus
    Posted Dec 09, 2013 03:42 PM
    So completely delete them from Airwave, and re-import them from the server?  I haven't been able to find a place to do it without doing this.
    Thanks!
  • 4.  RE: VisualRF not listing Unknown Campus
    Posted Dec 09, 2013 03:47 PM
    Do you have it on another server ?
  • 5.  RE: VisualRF not listing Unknown Campus
    Posted Dec 09, 2013 03:49 PM
    Airwave allows you to move a building to another Campus but not an individual AP since you have to place it in the right location
    So if you imported from another server , then you can move it over to the right Campus that you already created
  • 6.  RE: VisualRF not listing Unknown Campus
    Posted Dec 09, 2013 03:50 PM
    Heh, Ok, I didn't explain that very well.  We do not have them on a different server.  When I said re-import them, I meant let Airwave re-discover the devices, and place them from there.
    I didn't see any place to remove existing devices in Airwave from the VisualRF plan they're in, if I can't open up the VisualRF map containing those AP's.
    Hope that helps some!
  • 7.  RE: VisualRF not listing Unknown Campus
    Posted Dec 09, 2013 03:53 PM
    My map is only currently showing one Campus... which is all we really need.  The AP's I need are in a different Campus, which does not show up in the list.
  • 8.  RE: VisualRF not listing Unknown Campus
    Posted Dec 09, 2013 03:58 PM
    Yeah , so If you would like to remove the AP or APs from a particular map you have to go to the actual map and remove it and then the AP should re-appear again in the deployed device list .
  • 9.  RE: VisualRF not listing Unknown Campus
    Posted Dec 09, 2013 04:00 PM
    Dang.  Can't get to the actual map it's on.  I have a support case open for it, hopefully I don't have to remove-rediscover the devices.  Thanks for your help Victor!
  • 10.  RE: VisualRF not listing Unknown Campus
    Posted Dec 09, 2013 06:00 PM
    Try Disabling and Re-enabling the VisualRF Engine, Make sure you have backup of all your maps
