VisualRF Plan Build 448 issue
  • 1.  VisualRF Plan Build 448 issue
    Posted Jun 13, 2014 12:24 AM
    Hi Guys,
    I'm not sure whether I'm the only one who having this issue as there is no similiar issue reported here.
    I can't upload any type of floor plan after updated the VisualRF Plan to the latest which is build 448. "An Error Occured" whenever i tried to upload it.
    Please find the attachedments for your info.
    I've tried reinstall rfplan, java, flash player, update and reset IE to latest but not avail..
    Any clue?
  • 2.  RE: VisualRF Plan Build 448 issue
    Posted Jun 16, 2014 10:32 AM
    Bump, anyone know about this?
  • 3.  RE: VisualRF Plan Build 448 issue
    Posted Jun 16, 2014 11:12 AM
    I haven't experienced anything like that. If you uninstall/reinstall does ti go away? Additionally do you have any settings set to high security on IE?
    EDIT, I see you tried uninstall/reinstall, etc...Support may be your next best thing, but that is not anything I have ever seen.
  • 4.  RE: VisualRF Plan Build 448 issue
    Posted Aug 07, 2014 09:20 AM
    It happens the same to me.
    What I do is the following. I open VisualRF Plan in Compatible Mode. That launches the webserver in the background and tells to press a button to launch IE. Then I copy the URL to Chrome, and It Works!
    Hope this helps!
