Network Management
VisualRF Plan Invalid File Format
  • 1.  VisualRF Plan Invalid File Format
    Posted Apr 29, 2016 05:46 AM
    Hi, getting a message trying to import a DWG floorplan into VisualRF 7.7RC1...
    "Invalid FIle Format" - sorry but do not know the source application, is there a known issue?
     Seeing FUW Version 3.05 in the CAD Info window
    Need a list of file format version supported so I can go back to the customer and get data in a format we can import.
    Any help?
  • 2.  RE: VisualRF Plan Invalid File Format
    Posted Apr 29, 2016 07:52 AM
    Just convert the DWG to a jpg or png, I know they both work. :)
  • 3.  RE: VisualRF Plan Invalid File Format
    Posted Apr 29, 2016 07:54 AM
    Thanks, I have PDFs too - just wanted to know if there was a list of file types and versions.
  • 4.  RE: VisualRF Plan Invalid File Format
    Posted Apr 29, 2016 07:57 AM
    JPEG, GIF, PNG, PDF and CAD (.dwg and .dwf) filesshould all work. Personally I'd recommend conerting CAD files to png though.
